LWF Clutch Kit ....are these parts all I need
Hello guys;
I have been experiencing some slippage, and following the infinite wisdoom of the gurus I have made the decision of moving up to the LWF RS Clutch.
Can you experts tell me if these are all the parts that I need
Also my mechanic has noot done a 993 clutch, only the 70's and 80's pre 964 cars, what else should we be looking for, whats the dos and donts.
1 96410223931 OE Aftermarket (OEM) Flywheel
1 964 114 143 31 OE Aftermarket (OEM) Ring Gear
1 950 116 813 30 OE Aftermarket (OEM) Rel. Brg. Guide
1 996 11601530 Sachs (OEM) Clutch Disc
9 928 102 151 01 OE Aftermarket (OEM) Flywheel Bolt
9 900 067 020 02 OE Aftermarket (OEM) Pressure Plate Bolt
1 964 116 028 03 Sachs (OEM) Pressure Plate
1 931 102 111 00 SKF (OEM) Pilot Bearing
1 944 116 080 00 Sachs (OEM) Release Bearing
All help would be really apreciated.
Thank you
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Thank you
I will be removing the Engine and Tranny, inspecting for gasket leaks and possibly doing the spark plug wires, I will be pricing the the RS motor mounts.
Any thing else....Parts numbers apreciated.
Power steering belt, plugs, RMS, and the slave cylinder would be high on my list if I were in your shoes.
In fact, I am in your shoes. I'll be doing the same job this winter in a buddies garage.
Guys this is a great place...still would like to get some tips for my mechanic as he has not done any 993's, he has not asked yet, would be nice if VB or someone of his caliber could coment...
I know that when I had it inspected there was a small pin size leak on the cylinders, I guess I will find out when we take the engine out.
