993 Forum 1995-1998
LWF Help!!!
Old 08-31-2005, 03:54 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
try depressing the clutch much later when coming to a stop. Much like at the last second when the revs are near idle. I am a little shocked that you are having this trouble..
Old 08-31-2005, 04:05 PM
Alon
Alon's Avatar
Originally Posted by JasonAndreas
If your idle is around 500 then something is wrong. Try Monique's suggestion before you mask the real problem by adjusting the ISV. On the PelicanBBS it seems a lot of 3.6 transplants have a similar problem as well as a few regular 993 owners and the problem always pops up after their mechanic has the car and no one has figured out (or posted) a diagnosis (until Monique just did).
HERE are the ISV mod instructions from Tom.
Thanks. I'll try cleaning the ISV and check the electrical connections before actually attempting any ISV adjustments.
FisterD
FisterD's Avatar
I have a MY96 with the LWF, and when coming to a stop, clutch in, right foot on the brake pedal, the car will automatically rev when the R's drop. It sounds kind of cool, like I'm doing it on purpose, but it happens automatically. Just a slight rev, to keep it from stalling I presume. Does you car do this?
Old 09-01-2005, 12:18 AM
Rick Lee
Rick Lee's Avatar
I have the LWF in my '96 and never had any stalling issues. However, my idle does stay at 500 and it drives me nuts.
Old 09-01-2005, 08:39 AM
Alon
Alon's Avatar
I cleaned my ISV last night and all seems good so far. I saw the epoxy covering the three areas but didn't bother with any of it until I saw what it's like with a good cleaning.
Thanks for the advice guys.
Now it's time for my LWF...
Old 09-01-2005, 08:50 AM
Flying Finn
King of Cool
Flying Finn's Avatar
Ditto that.
Your idle revs are too low but by the way you drive you can prevent stalling issues.
Old 09-01-2005, 08:51 AM
dhicks
dhicks's Avatar
Alon
Was this the first time you have cleaned you ISV, was it easy, did you follow p-car thread.....what is the bit about the epoxy??? I plan to have a go at mine this w/e just to clean it as it seems a lot of people do this as a routine job .... how often should it be done?
Old 09-01-2005, 11:50 AM
only993
only993's Avatar
Hey guys, not sure if this help in diagnosis but when i unplugged the ISV is idled up to about 850-900. where it should be. Though is was surging, would this problem then be related to Vacum or the ISV.
Old 09-01-2005, 04:11 PM
Alon
Alon's Avatar
Originally Posted by dhicks
Alon
Yes, I had not cleaned it before. As for the epoxy covered screws, I was reading a thread that explained how to remove the epoxy and actually adjust the ISV to compensate for a poor or low idle. Luckily for me, the cleaning is all it needed. The ISV is right there, on top of the intake plenum so I didn't follow any thread for this procedure but if you want, go to www.p-car.com and check in their technical section, it's explained. It's a really easy job but wait for the engine to cool down because one of the clamps was a bit of a pin in the *** to loosen while it was still hot. A full can of brake parts cleaner and drying time was all that was necessary.
Old 09-01-2005, 04:51 PM
dhicks
dhicks's Avatar
Thanks, .... another job for this w/e
Old 09-01-2005, 05:19 PM
Alon
Alon's Avatar
It's a piece of cake, really.
Old 09-01-2005, 09:17 PM
Bill Verburg
Bill Verburg's Avatar
The ISV mod is simple, just dremel the center of the epoxy, break up what's left w/ a pick. 3 x4.5mm hex bolts are then exposed. Rotate the inner core clockwise to inc. idle
Old 09-01-2005, 09:18 PM
Bill Verburg
it's sensitive, just a tiny movement should be made.
Old 09-01-2005, 09:45 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Dirty ISV valves are typically slow to react, which become out of phase with air demand to maintain and quickly adjust for specified idle speed. I would think periodic cleaning will help.
Old 09-01-2005, 11:04 PM
gst
gst's Avatar
i had all the problems you guys mentioned, but had the MAF changed and most of the problems disappeared if not for the occasional stalling, i did not have the ISV adjusted and am not prepared to do it, the idling rev of my 94/95 euro 993 remains approx 750rpm. Before i changed out the defective MAF, it remained about 1200 rpm
Quick Reply: LWF Help!!!
