Oil Leak
Is the sender on the 3.6 in the same place? I have no way, at this time, to get under the car to even look. The only independant shop in the area won't work on 993's, so I am going to be stuck going to the dealer to even get this diagnosed.
Any tips or eprvious experience? Thanks!
Aaron
As long as I was there, and car was on the lift and ready, I had them do the oil change with both filters. Normally, I do this stuff myself, but with no lift (or proper jacks right now) and since the "Auto Craft Shop" (A cool DIY garage available on most major military installations, run by the Morale, Welfare, And recreation folks at no cost to the govenment..self supporting across the MWR system) at the old Ft. Ord is shut down, it just made more sense to have them do it.
All OK after I leave until I get to school (about 3 mile drive) and smell burning oil and have heavy smoke. Open engine compartment to find the standard overfill mess. ARGH! They can't have pulled such a bonehead move at the dealer?!?!? I was watching them, and they seemed to do it right, warming the engine properly and using the dipstick...
Go back at lunch, pissed, and leave the car with them with promises to figure out what they did wrong (their first thought was that the thermostat didn't open as expected, and they didn't give it enough time...Fair enough, small error.) They promise to clean up the mess.
When I got back to pick up the car, more bad news. They have (preliminarily) diagnosed the problem as being that the cause of the oil coming out of the filler was not an overfill. They have determined that there is too much pressure in the crankcase due to faulty PCV valve or another problem related to that. They say that since they filled the engine to the top mark on the dipstick (as is correct), combined with the fact (?) that the excessive pressure, since it can't vent properly, gets into the oil tank, that is what caused the cause of the overflow. (I had the car about 1/2 quart below the full line, so I wasn't getting the overflow.) They also said that the increased internal pressure is probably also causing the other oil leak.
Seems that the only way to access the PCV valve and related bits is to remove the intake and other top of engine stuff. From looking at it all, that seems to be true. Though this could be done with engine in the car, it seems like it would be a lot faster and easier with the engine out.
So, any input on the PCV valve being bad? (I did a search on "PCV" and got very little on on the 993 forum, which makes me think that this problem is uncommon) Any other possible causes? Since neither the increased crankcase pressure nor the relatively minor oil leak should cause any damage to other components, it seems that both of these will go onto the list of things to do next time the engine is out. (probably 12-18 months at least for me) Anybody have an opinion on that thought?
(Oh, and when I left the car the second time, I needed some of the keys on the ring, and without even thinking, I just left the ignition key, taking the remote with me along with the keys I needed at work. So, they couldn't move the car to go clean it up for me, so now I get to do this myself. Stupid on my part for not leaving the remote, so I get to do the clean-up...yay!
Vic
95 C4
I learned long ago not to have basic stuff done by the dealer. It all started long ago when I first picked up my 2 year old 993 at the dealer and found that after careful prep, they still had the car 2 quarts low on oil. But, as the prep sheet noted, they had carefully checked and confirmed that the antifreeze was full. Duh. Sorry for my anti dealer rant, but service has not always proven to be their strong point.
As I understand it, the "overpressure" situation caused by a faulty PCV valve/system probably caused the leak in the filter console/housing. This has probably been ongiong since I bought the car, or even longer. (I don't think it is something that would be part of a PPI type check.) I did not ever get the overflow from the tank into the engine bay because I keep the oil level about halfway between the marks on the dipstick. (This is the first oil change since I bought the car) The tech says he put the level at the top mark. As explained to me. since the excess pressure in the engine can't get out the normal way (through the PCV system), it goes into the oil lines and to the tank, and, with the oil level all of the way up, pushes some of the oil out.
Yes, this initially looks like the tank was wrongly overfilled, but, assuming the diagnosis of a problem in the PCV system causing higher than normal pressure in the crankcase is correct, I don't think it was overfilled. The service director said that I should not fill the engine up to the top mark until this problem is sorted out.
BTW, they base the diagnosis they made on the fact that, when the oil filler cap is removed with the engine running, the is an audible release of pressurized air. They recommend further diagnosis to confirm that it is the PCV valve/system. I don't want to pay for a fishing expedition until I have a bteer idea of the validity of this preliminary diagnosis.
Does anyone else have ideas or othee experinces with this problem?
Thanks!
Even though I do have a garage here, I am reluctant to buy the kind of good low profile jack and other stuff I need for the 993, because when I move back to Europe next year, I'll have to either sell that stuff or stick it into storage for 3+ years. The MWR Shops I described above are intended to make up for this problem, but there isn't one here. So, for the next 10 months, for any work beyond minor maintenance, I'll be stuck going to the dealer. (The only local independant shop won't work on 993s)
Welcome to CA. Previousely you mentioned that you'll be here in the summer after visiting family in AZ?. I guess the time is now.
Good thing the base commission recommended that both Monterey bases stay open, or else you'll be moving soon again. Bummer.
Now for the leak, which dealership was that? It may not be too far to come to our area for a second opinion. Guys at DEVEK, Don Wise etc. are real pros in 993s. I somehow have little faith in dealers.
Good luck and hope to meet you one day around here.
CP
The crankcase ventilation trick they pulled by removing the oil filler cap does not prove anything. First, it is a sealed system that does count on intake vacuum to vent. Older 911s would idle roughly if the cap was left off. So the cap removal with consequent rush of air (vacuum) is either an intentional ploy or just based on ignorance.
At least in my car it takes waaaay more idling to get the thermostat open.
And since they (and you) are not sure about overfilling or not, that's another sign they screwed up.
It's very clear (by reading the temp. gauge) when the thermostat opens.
I'd drain some oil out (1 quart or little more), clean everything, drive it until thermostat opens, then see where the oil level is. If the level is corect or too low and it still smokes like before, take it to the shop.
If it doesn't (smoke), get to the shop and let them hear what you think about them and their service.
I'll keep digging into the manuals, but any tips or ideas would be grat.
There is no PVC valve on a 993, the cc breather connects directly to the oil tank, the oil tank also has 2 smaller vent lines to the intake manfold and throttle body.
Overpressurization can be a problem w/ the 993 when displacement is increased. What happens in that event is the cylinder base seals get blown out. Never would have believed it if I hadn't seen it w/ my own eyes.
The GT3Rs use a trick cc breather w/ a one way valve to enhance cc vacuum
Armed with the knowledge from Bill, why don't you go down to the dealer and ask them to point out the PCV valve, if not on your engine, at least in a service manual, then let them clean up your engine when they can't find one?
911 engines don't like too much oil. If they are overfilled, they will blow the oil out all over the place, including into the intake, and make a big mess along with lots of smoke. The bottom mark on the dipstick means "add a pint", and the top one means "too full". The ideal level is halfway between the two marks. These cars have so much oil in the system that there is no danger of losing pressure, even if you are a couple of quarts low.
Overfilling the oil is a very common mistake, usually done by a new owner trying to keep the oil level gauge reading high when the car is at cruising speed.
It is easy to correct the oil level. Get a fluid oil pump from your local parts store for $10 or so (Sta-Lube makes a decent one), and pump out a quart or so. Get the engine up to operating temperature, let it sit idle for a minute or so, check and adjust the oil level.
Also, it's not difficult to clean the engine in a 993. Get the engine warm (but not hot), tape off the air intake, spritz it down with Simple Green, and hose it off. It is hard to drown this engine, but don't blast the ignition parts with a full-force spray. Blot off any standing water, then start the engine to help vaporize remaining water.
I'll bet once you get the oil level correct and the spill cleaned off, the engine will run just fine with no smoking. The little oil leak could have been that the filter needed to be tightened a quarter turn.
