993 Forum 1995-1998
Caliper DISCOLORATION
Old Aug 9, 2005 | 09:52 PM
Chicago993's Avatar
Chicago993
Default Caliper DISCOLORATION
Has anyone had the problem with discolored calipers? I have a 1995 C4 with SILVER Calipers. I track the car several times thru the year, and upon returning home from Gingerman Raceway in South Haven Michigan, I noticed that my front calipers are tunring a yellowish color. I assume this is due to the heat, but is this something I should be concerned with? The rears are still silver, but now the fronts are drastically different than the rears. Any help would be much appreciated.. I love this site...
Old Aug 10, 2005 | 12:35 AM
Bill Verburg's Avatar
Bill Verburg
Yes, it is common for that sort of thing to happen on tracked 993s, the front does most of the work so that is why the calipers are showing signs of elevated temperature only there.
The rubber parts in the front calipers are either gone or on their way out. Rebuild them.
The solution is to keep rotor temps down, cool air, is a first step. Many go to the 993tt/993RS brakes as a final solution.
Another strategy is to get the weight down, but that is neither cheap nor easy.
Old Aug 10, 2005 | 12:49 AM
Eric in Chicago's Avatar
Eric in Chicago
Discolored calipers are a badge of honor. You going fast, braking hard, using the car in the manner it was designed!!! Check your pads, you may have less than 1/2 of the pad material left, past half any your transfering even more heat to the calipers. If your planning on RA for Labor Day, really check your pads as that track will eat a set of pads over the course of a weekend.
Old Aug 10, 2005 | 01:17 AM
Chicago993's Avatar
Chicago993
Before going to the track I did the following:
Changed Brake Pads from stock to NEW Pagid Sport Pads F & R
Changed from rubber to Stainless Braided brake lines
Flushed brake fluid with new ATP Super Blue
It wasnt until after doing these items that my calipers started to change color in the front.
Old Aug 10, 2005 | 01:33 AM
Mark in Baltimore's Avatar
Mark in Baltimore
If anything, I would imagine that the Pagid pads would do a better job of thermally protecting the calipers. You're probably braking deeper and harder with all of your slow-fast goodies and that transferred energy is turning into excessive heat.
Old Aug 10, 2005 | 01:50 PM
ScottMellor's Avatar
ScottMellor
My Titanium coloured calipers look like nicotine stained fingers thanks to the Previous Owner, who could actually drive
