Parasitic Drain Question
Has anyone removed fuses with a meter hooked up to their battery to see if they could tell where the drain was coming from. My car has a 20 milliamp drain, not real high. When I checked it in January; that figure did not change whether the alarm was activated or not.
If my math is correct (which is saying a lot for me) I figured that a 18 milliamp drain on a 40 amp nominal capacity battery (10 hour rate-amp hour) would lose 1 amp/hour of capacity in 55.5 hours or 20 amp hours in 46 days, i.e., 6 weeks. So that would mean the battery would have lost 50% of its capacity.
My question is not intended to be an inquiry or discussion regarding what’s the best battery or the best charger or system for changing and/or keeping your battery charged.
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Never measured the drain with a meter but the battery will drain enough to cause trouble if left for two weeks or longer. Plus it is not good to let the battery deep cycle. I just use the on board trick charger if I leave it.
Cheers
Cheers
Technical Guru
There is a great 8 page Technical Service Bulletin for diagnosing a discharged battery. It goes through troubleshooting the alternator, voltage regulator, relays, ignition components. The TSB is part identifier 2706 and number 9402.
I have the written workshop manual but I don't think I have the TSB's.
I do have AlldataDIY for 3 other cars, not the Porsche, and I contacted them to see if they had the two you indicated. They said they had 2706 which is "2706 DEC 97 Battery - Revised With 70 Ah Rating"
They did not have anything with a 9402 on it. Are you sure that is the right number for another TSB?
Technical Guru
2706/9402 are the numbers in Service Information Book K (white book) from Porsche for a single TSB. The name of the TSB is "Diagnosing Discharged Battery". Another example would be, Part Identifier 4490 / Number 9406 -- "Wheel Alignment Specifications for the Rear Axle" (which describes changes made to the spirit level that is used to measure kinematic toe). I'm sorry I don't have them in a digital format or I would just send it to you.
