Remove headlight washer nozzles???
FWIW, its possible that not having windshield wash capability (if the car was originally equipped with it) may cause it to fail a safety inspection (if your state has that). I know that in Ontario, Canada it would likely be an issue (if they caught it mind you...).
Removing the headlight washers should be no trouble other than perhaps in parts of Europe where if you have HID headlights, washers are required. In that case the car will likely fail inspection if they are removed or non functional. Just a different perspective...
It does look nice without the headlight washers... but I would leave the windshield washers intact...
Cheers;
Eric
Cheers;
Eric
Rennlist Lifetime Member
Originally Posted by Flying Finn
I'll remove my headlight washers also.
I was thinking of welding the holes first and then with filler but as I'm afraid of rust (comes from living in a country that uses salt during the winter) I will have them do it just with filler.
Edited on 4 Aug. The above is wrong; I confused my cars. The 993 headlight washer jet snaps into the metal of the wing/fender which is obviously metal. As the thread has continued I've added this edit rather than deleting the error.
King of Cool
Originally Posted by phelix
Not sure what there is to rust; the headlight washers just snap into the PU and there's no metal involved.
