HOW to adjust the PSS9..???
Which way to turn them? Up or down is CLockwise or counter?
Since the fronts are covered with the blue rubber covers, I cannot tell.
To adjust the shocks, turn the **** counterclockwise to find the stiffest setting (1) and then turn dial back, feeling for clicks. +=stiffer
Yes, pull the cover off unless you have the tactile sensitivity of Light Fingers Louie and can crack a Mosler safe in your sleep.
RL Technical Advisor
