993 RS question
Hi guys,
I have a friend who owns a 993 RS with an airbag steering wheel. I have a 993 RS wheel on my 964 Turbo and had a spare 993 RS wheel which my friend has brought. His mechanic tho has told him it will not fit. Can anyone see any logical reason why he would say this? It doesn't make sense to me. Surely the spline is the same across the 911/964/993 range.
Any thoughts or ideas appreciated.
Lastly... lets say the wheel will fit. What is involved in installing it on an airbag car?
Thanks in advance
Thanks in advance
Numerous people have done it but the biggest problem is the Airbag fault code ... result from the change.
Try the search function... discussed often. Also a procedure to disable the fault code somewhere.
Good luck.
Good luck.
