265's on stock 17" rear rims?
It is time for a new set of rear tires. I currently have 225's on the front and 255/40 on the rear. What I am wondering is can I go with 265/40's for the rear? If I do, do they have the same rolling radius?
Proly not. the 265 should be taller than the 255. With 225's in the front and 255's in the rear its a good setup for less understeer. My suggestion is to keep it this way.
Addict & Guru
What Danny said, assuming you care most about balanced handling. However, if you have other priorities, the increase in diameter will only be 0.3" +/- which should not cause any issues (unless maybe if your car is lowered a bunch). The larger rears will result in about a 1.5% F-R diameter difference which is not enough to cause ABS problems. The rake will change slightly & your speedo may be low by 1 mph @ 65. Otherwise, should work fine, albeit w/more understeer than you now have.
Well the Carrera RS used 225/40 & 265/35 in 18s of course, but the priciple is the same.
You might want to think about 235/45 & 265/40
you will find that the slr(static loaded radius) and rpm(tire revs/mile) are much better indicators of changed gearing and/or speedo readings. The 265/40 is really not much larger(in general) than a 255/40 ~.1" in this area but there is a lot of variation in actual vs nominal specs from the various manufacturers
Thanks guys, my car does have the PSS9 kit on it. It is lower by about 1". I think I might stick with the standard tire for the street and get a different set of rims for the track. I am considering 18's for the track which I assume I can then use the 265/35's. Anyone have any 18" 8's and 10's for sale?
I run 235/45/17 fronts on 7" wheels and 275/40/17 rears on 9" wheels, all mounted up on standard Cup wheels. The Tires are Toyo RA-1. This combo works perfectly, andf the rolling radius is < than 1.5%, no ABS issues. I calculated this on an EXCEL spread sheet that all can have if they send me a PM with an e-mail address. If it were a perfect world, I would have 8" wheels on the front, and 10" wheels on the rear...I just didn't want to spend $3,000 on a set of custom wheels for the track.
Note I also drive these tires on the street...they are very quiet compared tpo my formar Kumho Ecsta MX tires.
