996 TT Wheels
Originally Posted by max911
Porsche put spacers on the 2S when it was delivered with the 17" cup wheels. (to fill out the wider fenders) They are not used when running proper offset Turbo twist wheels- 40mm ET.
Were you using the spacers on the 18" 993 twists pictured in your avatar ?? Maybe the spacers were on the car because those twists are narrow body (65mm) offset??
max
max
The sport wheels that came on my car are 65mm offset. I incorrectly assumed that they were 40mm because that's what the owners manual says. When I read max's post I went straight out to the garage and:
And, regarding the part number issue, I found this in another thread:
Originally Posted by Boston
I'm trying to match a Hollow Spoke Turbo Twist wheel. The part no. is 996.362.142.03. Do the last 2 digits of the part number i.e. "03"; represent the year of manufacture or will other Hollow Spoke 11x18 et45 match? Thanks.
Originally Posted by Tool Pants
The .03 is not a year and that part number is listed for a 2002 or older turbo. There is a bulletin which says that some rear wheels had an incorrect part number. You have the correct part number. The incorrect part number had 363 in it instead of 362.
The bulletin also says that your part number has been replaced by 996 362 142 11 and that this wheel is identical to your part number. This new wheel part number is listed for 2003 up.
However, your part number is still on the parts list, but that does not mean it can be ordered. Call your parts dept and see if it takes you to the part that ends in 11.
Thank you rennlisters. pinoysche, thanks for bringing up the topic so I could get my car straightened out.
