993 Forum 1995-1998
Bottoming out while driving
Old 06-28-2005, 12:30 PM
Alon
Alon's Avatar
Let's make sure that we're all talking about the correct wheels (picture attached). Forgetting the fronts for a minute, the Carrera Lightweights are 18 x 10 with an offset of 65mm. The Boxster are 18 x 9.5 with a more aggressive offset (don't remember the actual value).
Old 06-28-2005, 12:36 PM
chammond
chammond's Avatar
Alon,
265s in the rear. I have to check on the camber, I can't recall, but the car was aligned when the supension was done. At that time, I had 17" cups on though.
Chris
Old 06-28-2005, 12:38 PM
chammond
chammond's Avatar
Yep...those are the ones. 8 and 10s.
Old 06-28-2005, 12:41 PM
kkim
kkim's Avatar
What size 265s in the rear? (aspect ratio)
Old 06-28-2005, 01:02 PM
Alon
Alon's Avatar
I assume 265/35-18s in the rear. What brand of tire? Where were these wheels purchased? Are they in fact OEM because I've seen copies on e-bay lately.
This seems strange to me. You shouldn't be experiencing any issues.
Old 06-28-2005, 01:03 PM
chammond
chammond's Avatar
265 35 Conti Sport Contact2s in the rear.
Old 06-28-2005, 01:58 PM
kkim
kkim's Avatar
Interesting... I have not seen copies of these wheels, but I have not been looking for a very long time.
chammond-
Where did you purchase the wheels from? Are these OEM Porsche wheels?
Old 06-28-2005, 02:09 PM
chammond
chammond's Avatar
Purchased from a local Rennlister in Chicago. As far as I can tell, they aren't copies. They say made in Germany so I'm assuming they are the real deal.
Old 06-28-2005, 02:34 PM
chammond
chammond's Avatar
Here are a couple of picts of the tire/wheels. Hope they turn out ok, they are from my Treo. Does anything look suspect?
Old 06-28-2005, 02:38 PM
Alon
Alon's Avatar
Can you get us a close up of the hub area (unless you're sure that there are no spacers on there, even the slightest thickness)? These seem to be very agressive looking in their offset and that doesn't make much sense. They should almost be a bit inboard with the proper offest and the car they're on.
Old 06-28-2005, 03:22 PM
StatmanDesigns
StatmanDesigns's Avatar
Looks like they are the wrong offset to me, at least they are certainly sticking out beyond the fender lip. Obviously, they will rub the fender when the suspension compresses. Read the wheel near the valve stem, I believe, and tell us the offset number. If it is not on the outside of the wheel near the valve stem, then jack the car up and remove the wheel and read us the numbers on the inside of the wheel.
Old 06-28-2005, 03:50 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Is it an optical confusion, or do you have a lot of rear toe? Toe-in is what I am referring to..
Old 06-28-2005, 04:19 PM
kkim
kkim's Avatar
If they are OEM parts, the width and offset should be cast into to the wheel on either side of the valve stem. What does it read?
Old 06-28-2005, 04:54 PM
chammond
chammond's Avatar
It says 52. Is this the wrong offset?
Old 06-28-2005, 04:57 PM
kkim
kkim's Avatar
Yes, it should be 65.
edit... you are talking about the rear wheel offset, correct?
Quick Reply: Bottoming out while driving
