Fan Belt Sensor
Yesterday my fan belt sensor light came on. After searching this forum and finding what the meaning of this light was, I retrieved the sensor and quickly realized that it could not be repaired. Looks to me like a $100 part with a 2 minute installation. Got to thinking, if the ithe only purpose of this sensor is to tell me that fan belt is broken, there are two belts there. And when the fan belt breaks you know it....past experience. So will the cooling be effected if only one belt is functioning?
What I'm really asking ",,,is this another example of over engineering?" And can I just jump the connections to turn the light out and continue to drive without the sensor?
Regards,
John
Rennlist Small
Business Sponsor
The other belt (aft belt) is for your alternator which has another method of warning you when it fails.Just remove the sensor and test it with an ohm meter (or the like). Its just a microswitch that have been known to be fixed by tweaking its lever. This providing the roller bearing is still good and not making noise. Even this bearing can be replaced if needed..
