How low is TOO LOW?/What height after PSS9 install?
Rake should be at 1 degree down in the front. The correct way to measure the height is from under the suspension on a flat surface. 25" and something is usually the RS height measured on fender height but this way its not very exact measurement.
For me it looks really good and the fender height measurements are almost exact with mine on the cabrio. I have no issues on the street with this height, just like Matt said.
hmmm... those are about the same measurements I have on my car. Your's does look lower in the pictures than mine. Like Monique said, the correct way is to measure from under the car at the chassis points.
What size rims and tires are on your car? Maybe it's just an optical illusion.
Originally Posted by JasonAndreas
You don't have to be a paid member here to post. Your intentions might be good but the effect is usually the opposite of what your trying to accomplish. Brow-beating someone into a membership doesn't work and only drives people away.
Sorry for the rant, just sick of seeing it.
The rake should be 1 degree down in the front, which normally occurs when the front fender lip measurement is 1/4 to 1/2 inch HIGHER than the rear. Many people think that the down in front rake requires the front lip to be lower than the rear, which is incorrect.
Passed On
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
Too low, in my opinion - looks like some California low-rider POS. I would be worried about tearing up the underside on the glorious roads around Steelertown with the car at that height.
I got my PSS9 set to about top of the tires being even with the wheel well lip. No problems.
I have added an itemized cost for the complete install of the PSS9 and RS antisway bars to the "LOWER" page
http://www.johnfelker.com/993tt/lower/lower.html
If my original suspension ever fails I'm hoping to get the same set up - Nice! IMHO it looks a little low - have you scaped anything yet and have you got one of Gert's scrape bar thingies?
Cheers,
David
Cheers,
David
