Nitrogen for street tires?
Originally Posted by Ron
Does anyone use nitrogen for their street tires?
I ask because I just got a new set of tires for my SUV and thats what they fill them with. They say it will maintain a more constant pressure with changes in temperature, i.e., ambient temperature that is. Is that correct?
Apparently all Costco stores now fill tires with nitrogen.
Originally Posted by kary993
Yes, this is absolutely correct.
Most of us that have regular air compressors can try putting out some air on the floor and will notice that water will build up as you continue to spray the air on the floor. In fact most compressors have a valve on the bottom to drain the water tha builds up in the tank.
I don't know that nitrogen will retain less water under the same conditions. I doubt there is a difference. However, nitrogen is inert and will not oxidize. There is probably more benefit from that property than anything else. Oxygen is very reactive, but if you want something really reactive, try fluorine!
Marv
When I had an alignment done at Lucent they filled with Nitrogen. Tom told me not to touch the tire pressure until I came back. Well, that was about 2 or 3 months ago and my tire pressure hasn't changed at all. Don't know if the nitrogen has anything to do with that or just the nice new tires, but I was surprised to see that the pressure hasn't changed at all.
Originally Posted by dhicks
hahahaha helium, very funny grmnxtc....but would that make them sound funny too?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Discount Tire and Belle Tire here also use nitrogen. They have nitrogrn extractors, so it is always available to them. Because most of their business involves the use of compressed air driven tools (I was told by the supervisor), the dry air makes their tools last much longer, and is cost effective. Filling the tires will certainly stabilize the pressures over temp. changes, but I think this is an unintended benefit. At the track, I routinely see an 8-10 lb. increase in pressures, and am contemplating using nitrogen to reduce it. The stuff is pretty cheap (approx. $15-$20 a season with 12 events and 2-3 sets of tires). The disadvantage is getting a tank safely to the track. If you fill and purge a tire a few times, you'll get enough nitrogen % to make a significant difference.
Technical Guru
So is Costco selling snake oil?
I was at COSTCO and saw the sign touting its advantages. I actually considered getting tires there once, but I found their pricies were not that great compared to other retailers. But the N2 sign sealed the deal for me. I will never get tires from there....
But I do find myself craving joint juice and fish oil tablets after seeing their adverts on the gas pumps outside. Snake oil? Nah, they just hope you walk out with some more crap that just came off the cargo ship that you dont really need....
Still plays with cars.
It isn't snake oil. Dry gas expands less than gas containing water. Water makes things rust - no water means no rust. Some tires have steelo belts. N2 is less corrosive than air even if the air has been filtered dry.
Nitrogen is better which is why race cars and airplanes use it. Performance tire dealers always fill race tires with N2. I don't know if Costco purges tires or not, if they do, great. If not, well it's free so why quibble?
Best,
Best,
[QUOTE=Bob Rouleau]...Nitrogen is better which is why race cars and airplanes use it. Performance tire dealers always fill race tires with N2. I don't know if Costco purges tires or not, if they do, great. If not, well it's free so why quibble?QUOTE]
A-men ! Airplanes and Race cars go through much greater temperature cycles and so nitrogen helps. It is probably overkill on a street vehicle, but if it is free, then why complain?
Technical Guru
“PART 25--AIRWORTHINESS STANDARDS: TRANSPORT CATEGORY AIRPLANES 25.733 (e) For an airplane with a maximum certificated takeoff weight of more than 75,000 pounds, tires mounted on braked wheels must be inflated with dry nitrogen or other gases shown to be inert so that the gas mixture in the tire does not contain oxygen in excess of 5 percent by volume, unless it can be shown that the tire liner material will not produce a volatile gas when heated or that means are provided to prevent tire temperatures from reaching unsafe levels.”
Its a convenient source of dry gas, that I can understand but any other reason...
I'm more worried about blowing up my hotrod 4 cyl. than I am about the relative humidity of the air inside of my tires.
Who ever heard of tires rotting from the inside? Steel belts rusting out? I've been driving for 25 years, and I've never had a tire explode from rusty steel belts. every tire I've ever seen the inside of looked pretty darn nice compared to the outside of the sidewalls.
I think that in airplanes that are subjected to super low temperatures and very low ambient pressures it is completely valid to use a very dry gas that has less of a tendency to expand, but my car has never been at 40,000 feet, and it never gets to 30 below zero on the California coast.
Most of the tire shops in my area are offering nitrogen fills, so you're not married to Costco around here, anyway.
