Anyone here ever DIY a clear-bra install?
I've about given up on the clear bra. Local guy just can't seem to make it happen for whatever reason. The guys from the left coast can't stick to a DC area visit date. And I can't bring myself to pay $1000 for another shop to do it, when it's far cheaper to respray my bumper after a few yrs. www.xpel.com lists the kit I need at about $249, but rates install difficulty as "advanced". What to do?
Rick,
If your car has the stock C2 bumper cover, the DIY is well within your capabilities. I did it a couple of years ago on my '97 C2 using the Invinca-Shield kit. Areas protected were the front bumper cover (upper and lower - two pieces of film), hood (up to and above the crest), headlight surrounds, side-view mirrors and I replaced the factory pieces in front of the rear wheels that were marked up.
Invinca-Shield uses quality 3M film and their pieces are an excellent fit. They also have a a very good video tutorial for the novice. If done in an unrushed manner, with all the parts, pieces, solutions, etc at hand, you will have a good result.
When I put the Euro TT bumper on a year or so ago, I had the Xpel shop in Rochester install the film, as it was a quite a bit more complicated and I didn't have the time to do it. I would not reccomend doing the TT bumper cover as a novice, but the stock bumper cover is not difficult. All the other pieces are easy to install - the only potential PITA area is the bumper cover.
I did it for my car and it worked fine (Euro tt front bumper cover). I used the Invica-Shield kit. If you don't see what you want on the web site, call and ask. They have other options available.
Ok,I'm giving this local guy one more shot and then I'm doing the 3M kit. I just went through the photos and directions Xpel and think I can handle most of it. I wonder how I could do the front splitters though.
Rick,
Totally up to you, but IMO if you're going to DIY, I would use the Invinca-Shield kits. I watched the Xpel guys (factory trained shop) install their kit on my car last spring and it was a tough job even for them. For example, the headlight 'surrounds' in the Xpel kit require stretching and fitting around the entire headlight assy. The Invinca-Shield is a better design, falls right into place and offers nearly the same protection for this area.
Also, I know for a fact that Invinca-Shields customer service is first-rate. Several times I called to speak to them and they put me on with the guys in the shop that cut the film. Or if I screwed up a piece they would send me another at no cost - not even shipping charges. Most everyone here who has DIY the paint protection has used the Invinca-Shield kits - I think they are made with the thought in mind that the car owner is going to install the product, not a trained shop guy.
Yeah, I did everything on mine but the front splitters. After a few weeks the splitters look a bit rough already. What ever!
The key to a good job is practice. I use mostly the soap slip solution and only use the alcohol mix when I really have to lock a section in place. Invinca-Shield will give you a discount on replacing the pieces you destroy during the install process. Hey, I even did my Tundra.
Rick - I did it with good results. If you are doing more than one car, do the car with fewer compund (?) curves first. I did my S2000, was a snap. The P car was more difficult, but still an relatively straightforward DIY. Used Invinca Shield.
I use both mixes. I fthe piece is a tough one, I use the soap stuff, sometimes going to EtOH mix when it is in good position and need some help at the edges. for simple pieces, I just use the EtOH mix. Much faster.
Wash your hands, do it in a clean environment, and for the big pieces, get a second pair of hands to place them - it is much easier.
Best of luck!!
Best of luck!!
