PPI on Friday.
PPI done today: Results
Leakdown test: #1-10%, #2-5%, #3-9%, #4-8%, #5-9%, #6- 8%. What do you guys think?
OBD II Code- P1790
DME Actual Values: Don't know what this means? Help? Normal?
Range 1 Cylinder 1-3(TRA)
-0.09
Range 1 Cylinder 4-6(TRA2)
-0.08
Range 2 Cylinder 1-3 (FRA)
0.98
Range 2 Cylinder 4-6(FRA2)
0.98
Oxygen sensing (FR)
0.98
Oxygen sensing(FR2)
0.98
OBD II Code- P1790
-0.09
-0.08
0.98
0.98
Oxygen sensing (FR)
0.98
Oxygen sensing(FR2)
0.98
On the leakdown, they should talk to you about the condition of the engine and what they think the numbers signify. The results are pretty consistent cylinder to cylinder, which is usually a good sign. If you haven't searched "leakdown result" I'd do that. Lots of comments on test results.
