90 degree softee
I had the fortunate opportunity to talk with Steve Weiner today because I had a question about the powerchip of his I just installed and he said the softness was a function of the outside temp and explained what was going on in the motor. Thanks Steve.
We discussed an extra oil cooler that could be installed up front. I'd like to hear from others who have gone this route and also anyone who has had similiar experiences in the heat with their 993.
Good talking with you this afternoon,....
As we discussed, this is a somewhat complex issue as you were feeling the results of two different things.
Elevated outside air temperatures affect two things for air-cooled engines; they reduce volumetric efficiencies due to high cylinder head temps and lower the threshold of detonation. One doesn't see cylinder head temps, but you can watch oil temperatures and they lag behind head temps at all times.
When oil temps reach 210 deg F and above, engine power begins dropping and its not a linear relationship between oil temp and HP losses. its more logrimithic. Controlling engine temps is THE key for maintaining best performance (and longevity) in the air-cooled 911's.
The second issue is that the Motronic system's knock sensors reduce ignition timing as the heads get hotter due to incipient detonation increasing knock sensor activity. One can watch this process in real time with a scan tool (Bosch Hammer for '95's and either PST-2 or any generic OBD-II scan tools for the '96-'98 cars).
It REALLY pays dividends to keep a lid on oil (and thus) engine temperature to maintain best power, freedom from oil leaks, and best durability/longevity.
Higher octane fuels, do not "cure" the problem, they only give you some margin. I will say that 100 octane fuels are highly recommended for all these cars when participating in track events for all the reasons outlined above.
My 2 cents worth,.......
