993 Forum 1995-1998
Sunroof Problem
Old 05-25-2005 | 07:45 PM
StatmanDesigns's Avatar
StatmanDesigns
Default Sunroof Problem
I did a search but found no information on this specific problem that I am having.
When the sunroof is closing it pulls the air deflector down with a pair of plastic pieces that are spring-loaded. As the roof nears the closing point these plastic pieces are run over and the deflector is pulled down. The passenger side plastic piece has broken and now I have to hold the deflector down while closing the roof. Everything else works perfectly.
What are the plastic pieces called, and where can I get them, and how do I change them.
I could take pictures later today if my explanation is unclear.
Thanks for any help.
Old 05-25-2005 | 08:13 PM
dsandfort's Avatar
dsandfort
Just replaced mine last weekend, except mine broke on the driver side. Your dealer will know what they are called and should have them in stock. I got mine from an independent who had them.
It's an easy fix. There are 2 screws on each side that hold the "ramp" pivot in place. There are 4 or 5 screws that hold the entire deflector assembly in place. Take them all out and the whole assembly comes right out. It's pretty clear how it goes together.
I replaced the 2 ramps and the 2 deflector pivot clips for about 14$.
I can get you photos and/or part numbers if you need them. It's simple, "trust me".
Del
kkim's Avatar
kkim
There are a lot of pieces in the sunroof... just to make sure we're all talking about the same piece, a picture would be most helpful.
Old 05-25-2005 | 10:27 PM
graham_mitchell's Avatar
graham_mitchell
are you talking about this piece?
Old 05-26-2005 | 01:49 AM
StatmanDesigns
Yes Graham, that's the piece.
Thanks Del, I will stop by my Porsche dealer.
Old 05-26-2005 | 02:08 PM
177mph's Avatar
177mph
Does anyone know the part number for the actual air deflector piece? Would you believe mine has gotten badly rusted (very odd since theres no other rust on the car). and I need to replace it....
rich
Old 05-26-2005 | 02:14 PM
TomF's Avatar
TomF
I replaced a SR cable and those same plastic pieces a couple of years ago. The cable is a bit tedious, but the plastic pieces you referred to are cheap and easy to install. Be cautious about over-tightening any screw that is mated to the roof panel... the metal is soft. Good luck with your fix.
Old 05-26-2005 | 02:26 PM
aam993's Avatar
aam993
rich
It's 964-564-005-01-70K air deflector in black
Old 05-26-2005 | 03:29 PM
StatmanDesigns
Del
Part numbers would be great. That way I can call the dealer and make sure they have them before stoppin gby.
Thank you.
Old 05-26-2005 | 03:46 PM
jnor10's Avatar
jnor10
rich
I replaced my very rusted deflector about 2 yrs ago, looked at it the other day and noticed a new rust spot developing once again.
What is it with this part?
Jeff N.
Old 05-26-2005 | 03:56 PM
aam993's Avatar
aam993
Thank you.
911-564-127-00 hinge(aka "ramp")
It's not clear from the diagram what else do you need to replace when changing this hinge. Just in case, pivoting clip at windshield side of the hinge is 911-564-123-00.
Old 05-26-2005 | 06:55 PM
StatmanDesigns
Thank you Alexander. Just called the local P-Dealer and the parts will arrive in 3-4 days and they will ship them directly to me. I got 2 sets of each part, and the total is less than $15. Got to be the cheapest part on the 993.
Thanks all for the info and help.
Quick Reply: Sunroof Problem
