Need a little help
Need a little help
Hi guys,
I would like to install the isolation mat for the engine compartiment but I have no idea how the isolation goes in?
Wich side must be up? The dark side or the grey side?
Maybe somebody has a install picture or something?
Many thanks in advance
Cheers
Cheers
LiP - the insulation matting is fitted with the grey foam side glued to the body and the black side visible. This is the case on my car however I believe the insulation comes in either black or grey so for clarity the smooth vinyl side should be visible when installed with the foam side of the insulation glued to the body. Hope that makes sense and is of some help.
