crack-crack-crack
crack-crack-crack
I heard that noise .. sounded just like my car was getting shot repetitively by a b-b gun after a ride over some bumpy back roads when I came to a stop at traffic light. I was near a school and pulled over+jumped out as I swore I had been shot. A few weeks later I hear it again .. no school this time, but bumpy mountainous roads. Twice now in 2-3months. Got new bilsteins and H+Rs from VB.
Really sounds like its coming from the back window. I press my finger on the rear window seal and it feels like it gives a little.. not sure what's underneath.
The rear window brake light doesn't work and I believe the switch or at least wiring runs through the window. Initially I thought that perhaps the PO's window tinter might have cut something during that installation. Now I wonder if there is some body flex that is occurring that's impacting the rear window and then the brake light connection.
Anybody else heard this before? Think there is any connection to the rear window brake?
thanks
thanks
Hmmm ... some of the widebody cars have been known to unexpectedly shatter their rear windows, possibly related to the wiring for the brake light ... hopefully that's not a warning sign.
Vic
95 C4
Vic
95 C4
What year is your car? The earlier 94-95 models did have some problems with the windows coming out-I think it was secondary to the suspension set-up. Do a search, I'm sure this has been brought up before.
Al
Al
Addict & Guru
Might be the window creak - flexing against the body. Search here for "Pedro's" Ice Wax, pick up a spray can from REI (or a bike shop), & apply it. That may solve your problem for a while until it's reapplication time.
Check for delamination of the glass. look at the edges for what will look like white areas indicating the window is splitting. Have a Porsche dealer take a look if you find anything.
BTW, spontaneous front and/or rear glass shattering was not limited to WB cars.
thanks
thanks
The 'seal' you describe is just a rubber trim piece to hide the mating area where the window meets the body. It snaps into a very delicate and easily broken plastic channel that is part of the rear window.
The inoperative third brake light is not related to the window creaking. As you say, perhaps the tint installer disturbed something. The outside cover of the third brake light snaps off (is attached with spring clips) and the conections are underneath - perhaps the installer had this off and just did not re-make the connections?
