PSS9 Links
PSS9 Links
How low can one get with the PSS9s with standard drop links? Also, will RS links work with Euro TT/M030 sways?
Hoping to avoid custom (non OEM) links...
TIA
TIA
You can probably get to about 25.25" with the stock links, not too bad. The RS links will not work w/ the M030 (incl TT) sways. I got shortened, adjustable (w/o having to remove the shock), beefier links from Mirage (jae@mirageintl.com) for about $100 (no affiliation, etc.etc.).
Addicted Specialist
aof,
I have PSS9s with the original OE droplinks and RoW TT sways (22mm/21mm). The car is lowered to just a hair above 25" front and just below 25" rear. It's a great setup that looks marvelous and mean, and drives like it's glued to the road. You'll enjoy it! Hope this helps.
Edward
Edward
Originally Posted by Edward
aof,
Edward
Edward
Also, would you be kind enough to PM shots of your ride height?
Originally Posted by aof
Thanks TroyN- are you at RS height with the custom links?
But then you'd have to spend another $2K on a bump-steer kit!
Incidentally I am also using ROW TT sways, Edward had some input into that.
