Air Inject Check Valve
SAI and Air Inject Check Valve Cut-off are the same thing? the Air Inject Check Valve is about $76.00. I was going to change the SAI and about to order the part but wanted to make sure. TIA, David
I ordered mine from Gert awhile back. Here is the link to the part on his site...
http://www.carnewal-europe.com/cpx_p93109.htm
Is that what you are looking for?
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Yes, that is the one Bob showed me that he would be replacing on mine.
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
this little doodad, should be replaced every 15k or so. I have seen corroded check valves at 24k!!! Some say this doodad, could also be one of the cause's of the SAI problem.
Does anyone know where I can buy the special tool to remove/replace the check valve? or any ideas that you can share? I've seen the 'home-made' ones but I'm not sure if I can make one myself. Thanks.
