LSD friction plates ....
Steve;
I just came from my mechanic's shop and he had the LSD apart. It has only one disc on each side with a thick spacer.
what gives?
TIA, David
what gives?
TIA, David
RL Technical Advisor
Hi David:
Your mechanic might not be familar with the 993's "abbreviated" LSD,...
There is a drive (friction type) plate and driven (steel) plate on each side. The spacer IS the driven plate.
Originally Posted by Eric86Red911
So, is it correct that all 993s use a total of 4 friction plates?
Its fair to say that the vast majority of 993's use the 2 plate (4 plates total) LSD.
A few early '95 993's had the older 4-plate LSD such as what was used in the 964. The ONLY way to tell is to pull it out and have a look inside,...
Originally Posted by Steve Weiner-Rennsport Systems
Hi Eric:
Personally, I've never seen a 4-plate LSD in any 993 but others have so I defer to them on that one,.......
DO the TT's also have only the 2 plate (4 plates total) setup? (43k miles and ready....)
Technical Guru
Just to add to the confusion, the original 40% locking 964 LSD that was used up until MY92 (on NA models) also had 2 plates per side. Does anyone have a part number for the 993 LSD case, not the whole unit including gears & discs but just the case?
Originally Posted by jrgordonsenior
Hi Steve,
Sorry sir,.......
TT's are no exception here: they ALL have the 2-plate LSD's. At 43K, its not very effective any longer.
