Replacing bulbs in 95 basket handle 3rd brake lite
Have a couple of lights out (thanks Dan) in my 3rd brake light. It's a 95 so it has the basket handle. Appears there are just two screws in the bottom of the basket handle that need to be removed. Assume I then just pull out the lite and replace. Anything else I should know. Thanks. Mick
There is in fact a detailed write up, but I wouldn't even bother looking for it. Just get some bulbs from the dealer, a soldering iron, and you're good to go. An extremely easy DIY. I unscrew the entire basket handle from the decklid just to get more access to those 2 screws. And don't lose the two black plastic pieces in there that the 2 screws go thru.
