997 18" Wheels
997 18" Wheels
Will these offset fit a 993 NB?
Front 8 j x 18" offset ET57
Rear 10j x 18" offset ET58
I assume the front will need spacers.
Thanks.
Thanks.
The rears will probably stick out a little bit, but it will be ok as long as you stick to 265 width. If you lower the car, you may need to roll the fender lip ($30 heat gun, $20 baseball bat, 30 minutes). Remember, 65mm is ideal so you'll stick out 7 mm.
Oh, BTW, I'm currently lowered to 25" fender height (approx. 1" lower than stock?) with ET56 wheels, FAT Dunlop SSR 265 18" tires, -2deg camber, rolled fenders, and I'm not rubbing. Without that much neg camber it probably wouldn't work.
Keeper of the Truth
This was covered not too long ago:
https://rennlist.com/forums/993-forum/192134-18-997-wheel-fit-95-993-narrow-body.html
