1998 C2S Codes
1998 C2S Codes
There are four (4) option codes listed on the vehicle. C02, P01, TD5, & VA3.
Could one of you give me the details of each code. I give up trying to locate online. Thank You
None of those 993 options are listed in the Porsche Red Book. That doesn't necessarily mean anything, as I"ve found other errors/omissions in what is otherwise a very handy reference.
For 996s, the Red Book says VA3 is "Tourist Delivery Prep (no charge)".
-Chris
-Chris
Check here http://p-car.com/technical/option.html for options code. C02 and P01 are on there. I'm suprised you don't have more option codes on a C2S. Double check the sticker, there are more numbers below the codes you have listed above. The sticker is kind of tricky because the font size in the first column is different than the second column.
From http://p-car.com/technical/option.html:
C02: Emission Code (for all U.S. Cars - MANDATORY) This is the code for cars coming to the US fitted with a catalytic converter
P01: AM/FM Radio Cassette Player with anti-theft coding and removable control unit MANDATORY (except with P02)
VA3: Preparation/Modification (Tourist Delivery vehicles only)
TD5 is not listed...
