Fabspeed Maxflow Installation??
Subscribe
Apr 17, 2005 | 02:37 PM
I recently purchased an aftermarket Fabspeed Maxflow exhaust system (used) for my 1996 993 N/A. The only hardware that came with the kit was the mufflers, tips and straps. Am I missing something??
Upon removing my factory Gillet mufflers & tips the clamps and o-rings connecting the factory mufflers to the Catalitic converters seems a bit small for the Fabspeed mufflers. I am also a bit concerned about using the factory clamp to connect the Fabspeed tips to the mufflers.
Am I suppose to use the factory clamps and o-rings, or do I need to obtain additional parts from Fabspeed? Since they are closed today, I thought I would check with one of the SMEs on Rennlist.
I'll take a break from the garage until I get a response......
Thanks for the help!!
P.S. I am a Rennlist subscription member, although I havn't posted in a looooong time. One of these days I'll post some pics of my car (1996 993 Coupe, 6 speed, Red on Black, 41k).
Reply 0
Apr 17, 2005 | 03:05 PM
You'll need to use the stock clamps, and no need for the donuts from the factory setup. The mufflers should mat with the cats just fine.
Reply 0
Apr 17, 2005 | 03:48 PM
Thanks! I'll give it a go!
Reply 0
Apr 17, 2005 | 08:05 PM
FYI....turns out they installed much easier with the donuts. The seemed to provide a tighter fit using the o-ring between the muffler and cat.
Reply 0
Apr 18, 2005 | 12:02 AM
The donuts are needed to seal properly but a very easy install the only thing i replaced where the bolts for the clamps
Reply 0
Reply 0
Subscribe
