Lost My Front License Plate - Is there a better way to mount the front plate?
Originally Posted by SCMomentum
I don't like plates on the front of the car and the idea of keeping one in the car with a broken plate holder sounds like a great idea.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
When I park in a public lot or on the street I throw it in the front window. I have no idea if that will help or not.
Originally Posted by grmnxtc
Just to add... the way it mounts up and under the front bumper, if you removed the whole thing, then you'd never be able to notice it had ever been fitted. Only if you get on the floor and look up, and then see two small holes on the underside.
My car came with no front plate, but did have a new front bumper without the holes for the plate mount. Seemed a shame to drill into the front, when this thing is neat, tidy and unobtrusively mounted.
Keeps me "legal" too...![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Clive.
Clive.
David,
IIRC it mounts to the underside of the plastic bumper cover... I'll have to double check when I get home...and yes, two holes drilled into the plastic (IIRC!)
Even though it sounds "risky" mounting to the plastic, I've not had problems so far, and it's had more than a few scrapes on parking blocks and ramps into driveways all with no issue!
I guess it helps that the plastic has some "give" or "flex" rather than being a fixed structural mount point.
I'm a happy customer anyway....
Clive.
Clive.
Slightly OT, but has anyone tried the European-looking plates in front? They look like custom jobs that have your state license number but on a longer, narrower plate that looks like an EU plate. I've seen them on a couple of cars and they look better, but don't know if they keep the metermaids away.
Might look better, but still non-conformant to CA plate rules (and subject to a ticket)
http://www.dmv.ca.gov/pubs/vctop/d03/vc4852.htm
Clive.
Clive.
Clive.
Clive.
Should have known.
Clive.
Clive.
As promised, here's a couple of close up shots of the mount. Two screws up into the underside of the plastic and two of those "Y separating" mounts to hold them in place.
This thing is held fast when I try and tug at the plate... Gotta be some serious force to get it out.
Hope that it helps those deciding if it's worth it. (I think so!)
Clive.
Clive.
Clive.
Clive.
thanks again,
David,
The plates mount with #10 stainless-steel sheet-metal screws and beneath the plate bracket is a u-nut. This u shaped nut is about ¾” square and slides over the bumper lip for reinforcement. So the screws actually go through the plate, through one side of the nut, through the bumper and then fasten to the u- nuts on the far side.
There is no loose hardware on the far side so it completely installs from one direction.
Thanks for the pictures you guys. I may need to "borrow" them.
Jef
Jef
Upshift,
Send me a PM with your email and what pictures you want... The originals are 5MP so there's room for a little more "closeup" if you need it.
Great product!
Clive.
Great product!
Clive.
