Who sells CERAMIC PADS for 993 Turbos????
Hey guys...anyone know where I can get Ceramic pads for a 1997 993 Turbo? Any particular brand? I want to eliminate sqeaky noise at low speed stops and less brake dust.... Thanks!!!
Run stock pads on the street and track events that require fairly mild braking. Where consistent, lap after lap, heavy braking is required such as California Speedway and in my opinion Laguna Seca, put on a set of Pagid Black for the front, Pagid Orange for the rear...or Pagid Orange all the way around. Expect to pay $400 a set or thereabouts for a complete set. They are available from our sponsors, Viper Bob at DEVEK, Paragon Products, Group 9 Motorsports.
RL Technical Advisor
Hi:
Ceramic pads are the Pagid RS-19 race pads and IMHO, not the ticket for street driving.
As Martin said, factory Porsche OEM pads work the best for street use and have the lowest dust issues. Any high performance or race pads will make more noise and a bit more dust.
If you are experiencing some squeaking, make certain that you have the factory anti-vibration shims on your pads, clean the brake buildup from the holes in the rotors, and have a qualified pro look at the rotor surfaces to determine if they are excessively scored or worn. Putting a 45 deg chamfer at the leading edges of the pads also helps prevent noise.
Dust is a byproduct of braking friction; no dust, no grip.
Martin:
I too, carry these pads,..............(you always forget about me)
Martin:
