O2 Aft Sensor replacement.
I looked at a shop diagram, and couldn't figure out the exact loc of the left aft O2 sensor. Once I climb under to remove my engine tray ;-), should it be evident as to which one is which?
I KNOW it's the one after the cat, but from a quick look standpoint, I figured that it would be safer to ask the question anyway.
Thanks!
Thanks!
Yes, you will know which one it is once you get under the car. If in doubt follow the exhuast back from the muffler and its the first 02 sensor you hit.
Jamie
Jamie
