What could be the downside of chipping/flash software upgrade?
In doing some research, it would seem that a chip or software upgrade for the 98 993 S would cost about $1k and add approx 15-20hp. It would also seem that companies like POWERCHIP or RENNSPORT SYSTEMS (Rennlist Sponsor) are pretty conservative with their approach, guaranteeing no unreasonable wear on the engine, transmission, components, etc. Basically, the claim is that the engine comes from the factory "de-tuned" to accomodate varying gas octane levels, driver abuse, etc. By adding a chip or software upgrade, the tuner is essentially tapping into the full stock, OEM engine capabilities (oversimplifying a bit)...
Is the cost the only downside of this approach? Maybe its just me, but $1k doesnt sound too unreasonable to get our cars to 300hp+
What is the catch here?
I spent a lot of time on this prior to buying my Rennsport chip. Now, after several months of use, I can honestly say I don't know what the downside could possibly be. I think the closest problem could be the increase in the rpms at the top end but it's really only 300-400 rpm so it certainly isn't overly stressing anything. It really does feel and drive like a better "tuned" car as you say. Because it gives you more at the top, there is less lag after shifting. I've also noticed that there's more pull even at the lower end of 4th/5th.
If you've spent some time talking to Steve W., you will quickly realize that he knows what he's doing and certainly wouldn't do anything that he thought was short/long-term detrimental (definitely not a fan of the supercharger).
RL Technical Advisor
Hi Peter:
FWIW,... I do not change the rev limiter unless LOTS of internal modifications are done. Its at 6750 RPM and thats safe with stock rod bolts.
Originally Posted by pjc
Insurance?
PJC
PJC
i just dont understand why every member of this board wouldnt have this modification done if it is a simple, safe, relatively inexpensive way to add approx 15hp.... (?)
"i just dont understand why every member of this board wouldnt have this modification done if it is a simple, safe, relatively inexpensive way to add approx 15hp.... (?)"
now you've got me thinking about this as well!
Originally Posted by PedroNole
Agreed, but then again, I don't understand why everyone doesn't have a cabriolet either....to each his own. That said, the '96-'98 chipping process is a lot more money than the '95's
"Plus, no CEL triggers in my OBDII"
are you saying that you had the software reprogrammed so that no CEL light would be tripped (even the SAI port sensor gets tripped)? if so, then reprprogramming the software would be an economical way to fix the SAI/CEL problem...
Reflashing for 96 cars is even more than 1k. You need to provide a 97-98 DME plus have the reprogramming done. If it were only 1k to me, it would have already be done in my car, through Steve.
Technical Guru
