Help!! Changing Spark Plugs... Dropped plug... How to Remove?
Okay, got around to changing (well, trying, anyway ) the plugs today and have done the easy ones so far (bottom driver's side) and have moved to the upper driver's side when I dropped a the plug in the engine while extracting it.
Have tried for an hour now to reinsert the spark plug tool back into the hole to retrieve the loose plug, but have been unable to get the plug tool over the top of the plug to grab it. Anyone have any ideas on how to retrieve that loose plug? It seems loose as I can insert a screwdriver down there to move it around, but can't seem to get the plug socket over the top. Can it get cocked sideways in there?
Thanks for any ideas.
RL Technical Advisor
Hiya Kelly:
Sometimes a strong magnet can drag it up but if you don't have one or its wedged in there, pull the valve cover and you'll be able to fish that plug out very easily.
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Ack. that is what happened to me on the worst plug possible...the right top forward most plug. I got a mirror to see where it was and was able to slide the socket over it. The socket has a little foam piece in it to hold the spark plug so I was able to get it out. Fishing is the only way I know or a big magnet.
Good luck!
Good luck!
Mark, Steve, Bruce,
Thanks, but I got it out. It was loose from the plug hole and I had already tried a magnetic tool, but seems like the top of the plug has a copper cap on it. The body of the plug is steel, but was unable to snake the mag tool that far in. I finally used some rubber hose that was just the right inside diameter to slip over the plug insulation portion and out it came!! Thanks for your suggestions... it's on to the other 8 plugs now. ... and these are supposed to be the easy ones!!!
Mahalo guys... Happy Easter to you!
Originally Posted by Father of 3
Good for you Kelly. And to think I was proud of myself for changing my rear hood shocks!
I've done the hood and frunk shocks before and they are no piece of cake, either. You should feel proud!
I just finished installing the last of the plugs. On the passenger side, after I removed the shield, like Robin says to do, to get at that forward top plug, I decided to change all the plugs from below. Worked out very well as there is a lot of room to work once that shield is out of the way. Still, that one plug is a PITA to get to. I bent the electrode removing the old plug with the spark plug socket, so on installation, I used the rubber hose trick to get that plug started in the hole. There is very little room to work on that one plug, but it is doable after some choice words.
Now, all I have to do is remember how everything goes back together, then it's on to changing the fuel filter.
Thanks, guys!
Aloha Kelly, happy Easter too! How long did the spark plug job end up taking? I think this is one that I'm going to have the shop do, just sounds like the pain vs. fun ratio is too high.
Are you, or have you already done your distributor caps and rotors? I'm going to do these next. Good luck on the fuel filter.
Congrats Kelly on saving lots of $$ and tackling another DIY.
As I understood an engine drop was needed to change the plugs or is it much easier with the engine out? Do all shops not bother and go straight to dropping the engine? Just seems like an unneeded expense [dropping the engine] for just one plug(?).
It would be great if someone can come up with tool for extracting that PITA plug, if it's at all possible.
Great job Kelly.
Great job Kelly.
Great job Kelly.
Great job Kelly.
Passed On
Engine drop isn't necessary, altho it would sure makes things easier. Haven't gone that far yet.
I can get at that upper plug with my custom-built spark plug socket. Want details? Search the archives.
Happy Easter to you and your family, Troy. Hope your young one had a great time Easter egg hunting today. Haven't seen you on the board much, lately. Hope your car is running great.
BTW, I still owe you an email about summer. Hope your plans are going well.
Thank you for your many contributions to the board, Ray.
Nice job Kelly. I also just picked up a new fuel filter and will attempt that next.
I might suggest that anyone attempting the spark plug change, take a new plug to Sears and test out a new spark plug socket for "grip". Investing in a new socket can make the lob a lot easier.
