993 Forum 1995-1998
!@%! CEL: Code = P1115
Old Mar 23, 2005 | 09:49 PM
911's Avatar
911
Default !@%! CEL: Code = P1115
Hey all,
I got the bloody CEL today and I just checked it w/ the scanner. The code came up as P1115. Does anyone have any idea of what this is? I checked one website and it mentioned a problem w/ the idle, I think.
Any help would greatly be appreciated. Thanks.
Rich
PS: How do I turn off the CEL? Thanks, again.
Old Mar 23, 2005 | 09:55 PM
911's Avatar
911
Okay, I just figured out how to get rid of the CEL (just read the directions )...
Old Mar 23, 2005 | 09:57 PM
graham_mitchell's Avatar
graham_mitchell
it seems to be O2 sensor related but I didn't find a reliable source.
Old Mar 23, 2005 | 09:58 PM
911's Avatar
911
Thanks, Graham...
According to one site, this is my problem:
1115 Idle Control Interrupted
Translation, anyone? I believe I have a fuel pump going out, so could this affect the car's idle?
Old Mar 23, 2005 | 10:02 PM
paradisenb's Avatar
paradisenb
I can't believe it. Graham did not find a source or a link, video, photo. You're slipping Graham. You always got a relative answer.
Old Mar 23, 2005 | 10:03 PM
paradisenb's Avatar
paradisenb
Absolutely. Have you changed the fuel filter?
Old Mar 23, 2005 | 10:05 PM
911's Avatar
911
Randy,
I'll cut Graham some slack since I think it's in the early morning hours for him right now.
graham_mitchell
was that a Porsche OBD code? Different manufacturers use the same code for different faults.
7 Porsche Models That Have Aged Like Fine Wine
Old Mar 23, 2005 | 10:07 PM
911's Avatar
911
Graham,
I believe so. I went to a website that had links to different manufacturers.
Old Mar 23, 2005 | 10:08 PM
911's Avatar
911
Here's the link:
http://www.troublecodes.net/technical/
Old Mar 23, 2005 | 10:48 PM
911's Avatar
911
Okay, thanks to my Hawaiian bruddah, Kelly (kkim), he kindly pointed out that the following is the proper diagnosis for my CEL.
Compliments of: http://iequus.com/obd_def.asp
P1115 = O2S Heater 1 Ahead of Catalytic Converter Cyl. 1-3
What exactly does this mean? Thanks, again, everyone!
Old Mar 23, 2005 | 10:57 PM
1999Porsche911's Avatar
1999Porsche911
It means that the O2 sensor on bank 1 did not reach it's pre determined resistance (heat level) in a specific amount of time after engine startup. This could be a bad ground of the heating wire or a bad sensor itself. If the CEL only came on once, I wouldn't worry about it unless it started repeating. Then check the connectors and wires and probably replace.
Old Mar 24, 2005 | 02:12 AM
Father of 3's Avatar
Father of 3
I was thinking the same thing.
Old Mar 24, 2005 | 09:31 AM
coltj's Avatar
coltj
Fault codes that start with P1 indicate a Powertrain(P) fault specific to the car's manufacturer(1). A code that starts with PO(zero) is a generic powertrain code common to all.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
