Alternative to Porsche's OBD-II laptop?
Hey everyone,
question for you... does anyone know if there is an alternative to Porsche's $10,000 laptop to access the OBD-II system in newer Porsches? I've heard from, i guess a source that I don't really trust, that there is no alternative if you want it to access every functions and do more than just read a few fault codes. I noticed pelican sells one or two OBD-II code readers, but I'm not sure what functions they'll access
Also, I find it incredibly hard to believe that no one has come up with a way to use an actual PC laptop with some software and a link and do everything Porsche's laptop did.
If anyone knows anything about this I'd really appreciate any answers.
Thanks,
Andrew
Thanks,
Andrew
I think your wastin your time looking for this
Have you tried searching this topic?? Do a search and you'll find that short of a Hammer there is very little you can do beyond reading fault codes.
Engine Load
Timing
Fuel Trim (Both Banks)
O2 voltage (All 4)
MAF
Coolant Temp
Engine Compartment Temp
Originally Posted by 1999Porsche911
That is not true...do a search and you'll find that there are various software apps that people use that will show you alot of the sensor readings in addition to resetting codes. Less than $200.00. Get one that at least reads the following:
Engine Load
Timing
O2 voltage (All 4)
MAF
Coolant Temp
Engine Load
Timing
O2 voltage (All 4)
MAF
Coolant Temp
That's a far cry from something that "does everything the Porsche laptop" does...which is what Andrew is really looking for. He's looking for something that can make adjustments to the Motronic system...having the ability to clear codes is not even close to all that the Hammer can do.
What are some of these programs you refer to? I have yet to come across anything worth buying other than a good $100 OBDII reader.
You can buy a standard OBDII scanner which will access ALL the Porsche DME
codes, data, & readiness for less than $100. All vehicles sold in the U.S. starting
in '96 were required to implement the OBDII standards for engine diagnostics.
The problem arises on Porsches when trying to access the other ECUs in the
vehicle, e.g. SRS, ABS, Immobilizer, & etc. That requires the Porsche PST2 or
its' update. There are other "solutions" to an actual Porsche tester other than
the PST2 which some have.
Obviously, for the earlier non-standard OBDI used on the 964, 928, & '95 993,
the Hammer must be used or its' equivalent. John Speake here on Rennlist
provides the "Spanner" for the 928 which functions like the Hammer but only
accesses the 928. Since he has basically 75-90% of the Porsche Hammer's
capabilities, it should be fairly easily to expland it for the 964/993, which he'll
probably do.
Check JDPorsche for John Speake's Spanner.
probably do.
Originally Posted by Lorenfb
......John Speake here on Rennlist provides the "Spanner" for the 928 which functions like the Hammer but only accesses the 928. Since he has basically 75-90% of the Porsche Hammer's capabilities, it should be fairly easily to expland it for the 964/993, which he'll probably do.
$200 is a lot of money just to do that...btw what coolant temp in the 993 are you referring too IMHO none of the monitoring functions you list are very useful for the money spent.
The question was about readers for "newer" Porsches and they are all water cooled. Secondly, if someone doesn't want to invest $200 in a good scanning software, then they are not serious about the proper turning and operation of their car. This is a must for today's vehicles and the software will work on all car.
btw, is having a full leather interior really worth mentioning in your sig space?
Loren, do you know what any of the ""solutions" to an actual Porsche tester " are? Basically OBD-I is no problem, you just use the bosch hammer, and honestly the hammer works fairly well on reading codes up to '98, but that's about all it can do.
My problem is the PST2 is an antiquated POS in my humble opinion, and it's just not worth it to sink that much money into something limited to reading ECUs... I'd much rather be able to run it off a laptop which is used for many other diagnostic functions. The problem is most software will work with Mercedes or BMWs, but Porsches seem to be a problem. I'd be interested in any of the alternatices that you mentioned, so please let me know.
Andrew
Andrew
Digging this one up from the past...
Just wondering if anyone actually ended up making any kind of software that would emulate a PST2. It would be an interesting project for the enterprising P-car geek.
There're now two WIN O/S apps:
1. www.autoenginuity.com - about $250 for OBDII 993s
2. www.durametric.com - about $700 - $800 for OBDI & OBDII 993s
and OBDI 964s
Neither is as powerful as the factory Porsche testers. But for 99% of
what DIYs do, they're more than adequate. These provide more than
generic OBDII scanners allowing access for most/all Porsche ECUs.
and OBDI 964s
Anyone that knows if there is any simpler way of getting the data from the OBD1 port? I assume that a simple pc with freeware and a cable could do the trick? Or is it a special protocol RS422,/485/Modbus that needs to excersised transporting the data?
