Not sure what exactly a "clutch kit" is. Does this include the flywheel? Is this a total clutch replacement? Definitely does include the slave, right? There was no wheel alignment done? Why was the oil listed under this work order for the clutch?
Did a search and learned a few things, but not the exact answers I was looking for.
A standard clutch kit includes clutch disc, pressure plate and throw-out bearing. I don't know why the guide tube would have been replaced, unless a non-OEM flywheel were also installed. But that clutch kit is far too cheap to be an RS kit.
993-116-911-01 is just a pressure plate, clutch plate and release bearing. The kit doesn't include a flywheel or slave cylinder and the reason they listed 10 quarts of oil is they needed to drain the oil before they could drop the engine.
