Weather Stripping ?
Weather Stripping ?
I wanted to see a pic of the driver side door opening to see what the weather stripping looked like. I need to replace the Door seal on the drivers side that goes all the way around the inner opening.
My question for the pic is, is there suppose to be a weather strip that goes on the top half only, or is the outer door frame seal that is on the door itself all there is?
Thanks in advance.
Thanks in advance.
Texas91 - I have the same pic from the Performance Product catalog. I can't determine if upper half peice is one that goes on the inside of door opening or is it the rubber/felt strip that goes around the top half of door itslef, meaning there is no weather stripping on the inside of the upper door opening.
Mine has developed some increasing wind noise on the driver's side only, yet all the weather stripping on the door and the entry area looks fine. I tried adjusting the striker plate position, but no change. I guess I will only find out if I replace it all.
