Top 10 Tips to Make Your 993 Last Forever...
what about rust -- does anyone periodically check in the danger areas for rust?
what about maintaining seals...prevent from cracking by using Einszett seal treatment or other stuff...
RL Technical Advisor
Originally Posted by icerbofh
Steve, why the keeping the fender wells clean?
Look at Jonathan's question above,....
Its a rust prevention measure. I've seen hundreds and hundreds of these cars and most rust problems begin behind impacted dirt, mud & leaves in places that people never take the trouble to look.
The factory galvanizing doesn't last forever,....its a sacrificial layer.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by mrsullivan
can someone elaborate on:
" 18) if you lower a US spec car be sure to remove the 18mm spacer above the shocks"........
Passed On
1) Don't drive it to & from work.
2) Don't hit the track or autocross lot.
3) When you do take it out, give it a good "Italian Tune-up" - drive it on an empty back road for at least an hour. No cell phone use unless car stops dead and you need a ride/tow.
4) Change oil & filters every 6K miles; use Mobil 1 0W40.
(I don't abide by (2), but strictly abide by (1), (3), & (4). '95 993 has 87K miles on original clutch, tranny, and engine. Engine is dry as a bone - no leaks - and I get 3K miles/qt. Because of (2), think I'm on about my 5th set of front rotors.)
Chris,
. I just signed up for Thunderhill Feb 26-27 so I'm psyched to try all the new mods out.
Steve, ah thanks. Are there any tricks to a quick, effective clean to the bottom of the car? I've picked up a bunch of stuff due to an OTE
but I figure since I wash my car about 3 times a year and live in California, I should be pretty safe.
I use a variety of citrus-based cleaners and our smaller pressure washer hooked to the water heater. I am VERY careful how I use it,.....
Done carefully, the bottom side can literally look like new.
my quick thoughts in addition to above:
1) place trans in neutral and release clutch at traffic lights.
2) pause very slightly in neutral when shifting.
3) over maintain car with fluid changes -- engine and trans oil, brakes, clutch slave cylinder, power steering, all filters, etc.
4) if store car, make sure it is stored properly, plus take measures to avoid mice.
5) if have acid battery - check monthly battery area. once yearly wash area with baking soda.
6) if have cab keep top up overnight
7) don't swing doors past stoppers
8) Get to know a trusted tech/mechanic before you need service
9) check instrumentation after start up and regularly when driving
10) read Rennist and share your knowledge and experiences
HTML Code:
at 125+ when all of a sudden I got wipers swooshing across the glass
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
That is why I removed my wipers and motors...although it is a dedicated track car (actually removed for weight). Can't tell you how many times I have had the wipers running on the track before.
Gordon,
Thank you for helping hitch my car up to the Jeep 5.9.
