Lightronic Problem
Addict & Guru
After you check the applicable fuse, swap the Litonic's D2S HID bulb from the driver's side to confirm if the passenger's side bulb is bad. [Don't touch the glass w/your fingers, or use clean gloves].
Beyond that I suggest you take it to a dealer if you're not entirely comfortable trouble shooting a very high voltage circuit. BTW, if you need to replace the HID bulb, drop me a PM. I've got a couple in my garage.
