ceramic coating
Originally Posted by David in LA
Thanks Joe. I assume you had to remove the baffles first.
Yes, I did remove the baffles. They cleaned out the inside of the pipes pretty nicely. When I bought the baffles there was an option to have them ceramic coated as well. In hind sight I probably should have done this, it was like $5-10. Also I would recommend if you have any dings or small divots in your pipes like I did to try to sand them out as much as possible, another thing I wish I had done (the bottoms of my pipes had some divots in them from probably hitting on driveways) as these show up in the finish. I hadn’t thought about doing that.
POACB
So apologies, if this is a dumb question... If the mufflers run cooler - where does the heat go? Preferably out the back, right... I'm assuming that the mufflers conduct a certain amount of heat away from the engine - with the ceramic coating, is there a chance that they conduct less and some of the heat could be trapped resulting in a hotter engine...?
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
Originally Posted by STAR57
Just took my Tips to be Ceramic Coated, he said about 32.50 us ( 40.00 Cad ) , should I do the whole exhaust???
its a 9 year old car with the original exhaust.
FF
FF
