ROW M030 Sway Bar Drop Link Installation Set UP
I'm installing the ROW M030 suspension set up. Does anyone have any pictures of the FRONT sway bar and drop link installation. I'm told that the "white" paint mark on the stabilizer bar should points to the Driver side installation. However, the set up just doesn't look right. Any pictures or directions would be greatly appreciated.
as i recall, the bar curves down (like a frown). if you try to put it in the othe way, it turns up. i don't recall seeing any paint markings on my bar. the drop link has a hole on one end, and a stud on the other. the stud end goes into the hub. hope this helps. if not, i blame my boss.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The Pet Diagram for the ROW MO30 Set up is wrong. The ROW MO30 Front droplink sits on the outside of the stablizer bar, not on the inside. Per the note above, a paint mark is on the Driver's side of both front and rear bar. Also, the ROW bar must be slightly reamed out to accept the 12mm (or was it 10mm bolts)
