Rotor Question
Rotor Question
After reading a few of the threads on steering wheel vibration under brakeing, I decided to take some of the advice and clean out the holes in my rotors. I jacked up the car, put it in on jack stands, and started cleaning each hole using a drill bit. After getting about 3/4 of the way done, I came upon a hole that I could not get the bit through. I got out the flashlight and started looking at the rotor to see if I could figure out what was blocking the hole. What I saw was a piece of fairly thick wire bent in a U and wedged in the vent slot. Then I saw the same thing in the next vent over. Am I correct in guessing that these wires were placed as an attempt to balance the rotors?
No way to balance the rotors. My guess is some kid messed with them, knowing what the result would be. Just to be more clever than to key the car.
Seen them in a number of the rotors it will be a w shaped piece if you pull it out. Sort of a V in the middle with 2 smaller U's on each end if its the same one I've seen. Always have yanked them out when found with no negative side effect. Not sure why they are there but it is my guess they are used to hang the rotor during manufacturing somehow.
RL Technical Advisor
FWIW,..after some conversations with engineers from ATE and Brembo several years ago, I learned that those little wire clips are there for balancing purposes.
I leave them alone.
I leave them alone.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I leave them alone.
I leave them alone.
Oops. Well, that is why I take my car to the people like Steve who know.
I left the clips in, and there does seem to be a reduction, but I haven't spent a lot of time in the car yet. I should know more tomorrow. I'll post an update then.
The wires are definitely balance clips. I have been and continue to be involved in the performance brake business and can attest to this type of balancing. It is not as common as it used to be as mill balancing have become the preferred method. this is where the edge of the rotor is machined or milled to correct the balance.
So, bsaed on my drive in to work today, I am seeing some improvement, but the vibration is still there. One thing I did not do was to try and clean the rotors as some have suggested. If I get adventurous I will try that this weekend.
my car also vibrates under braking. i have the a set of the big reds. my local shop drove it and said they are a bit warped- suggested turning the rotors. has anyone ever turned their cross-drilled big reds?
