993 Forum 1995-1998
Deflating the spare tire?
Old Nov 2, 2008 | 12:12 PM
FisterD's Avatar
FisterD
Originally Posted by GratefulJED
If I remember, someone said to get one of thos racheting (sp) straps and put around the tire - that should do it.
That's what I did. Remove the valve stem and crank it down. It's pretty easy, like others have said.
Old Nov 3, 2008 | 03:21 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Once you remove the valve core they collapse extremely well. They were designed to do just that. What I suggest you do after you inflate it and fully wash it off is you dry it and then using liberal amounts of baby powder, smother it with that stuff. The talc helps promote longevity in rubber. I wouldn't wipe off that much of it either as you deflate it. Then store it back in the trunk. I use that stuff on the rubber door seals as well particularly if you are in an area prone to freezing temps in the winter.
