Benefit of Dual Purpose Battery; Starting and Deep Cycle
I'm going to replace my battery with a seal unit, either the Optima or Exide Orbital, both are sold locally. Both companies make a dual purpose, ie. starting/deep cycle battery. Would there be any advantage to this type of battery because the car uses power even when it is not running?
If your car is regularly driven, or spends off days on a trickle charger, there is no benefit to having a deep cycle battery per se in your Porsche.
Modern cars like the 993 will draw 1/2 to 1 amp/hour per day from a battery just sitting in a garage, though. So if your car sometimes sits for a week or more at a time, a battery built to 'deep cycle' may well last longer than a regular starting battery.
I think the Optima has 'Absorbed Glass Mat' construction, which makes it physically tougher than a normal starting battery, and also gives it deep cycle properties. It is a very good battery, but you pay more for its advanced construction.
Chip
Chip
