Warning Light Interpretation
Still without an owners manual, and I'm trying to understand the various warning lights on the dash. I've done a search, and can piece a few of the icons together, but still need help with:
1) on the clock, at the 1 o'clock position - looks like an arrow pointing down on the rear panel
2) on the clock, at the 5 o'clock postion - two circles connected by a belt. I believe this is for the fan belt?
3) on the clock, center position - a circle with 6 bars surrounding it
3) on the oil pressure gauge - green ABD; believe this is for the limited slip diff. (my car has this option)
4) on the oil pressure gauge - red ABD; located directly ajacent to the green ABD.
thanks all for the assist.
1. wing is not up, but will shut off after the car reaches 4 mph.
2. altenator belt warning light, if it comes on, you belt has come off....stop now!
3. I think thats the abs sytem check
3. abd controls brake pressure under wheel spin, not having to do with the diff.
4.Abs system light
4.Abs system light
