Took the plunge... Bilstein HDs on the way.... install them myself?
I've had a box with H&R springs sitting in the corner of the garage for 9 months. Getting my car out of the spray booth with new RS splitters, so time to get her closer to the ground. Ordered the Bilstein HDs with the extra 30mm of thread from Gert (along with his FPB). So now....
I am NOT a DIY kind of guy. I try, I have the tools, I have the room, but I do more damage than good most of the time. Should I even attempt to install the springs and shocks? I know I'm going to have to take her in for the 4 wheel alignment anyway... but I've been told that I'm looking at over $1000 for the install and alignment.... ouch. Is is really that difficult?
Richard,
You do need a degree of confidence to do it, but with the info and help available from this board, you should consider it. Look over the many posts of people that have done this and make up your own mind.
If not, is a trip up to VB's place too far to get it done right? If I lived anywhere drivable to his location, that's the only place I'd consider having it done... most likely less than what you've been quoted for the install.
p.s.- if you do have VB do it, take extra money!
If you decide not to DIY, I've heard good things about both West End Alignment and Johnson's Alignment, both in Torrance. When I do the HD or PPS9 thing, I will likely choose between DIY and one of these two shops. West End is run by a guy named Darrin who I've read numerous rennlist compliments ("Darin does excellent work and he used to work for Johnson's alignment for fourteen years. 310-808-9233").
If you go with either West End or Johnson's, I'd be interested to hear feedback. If you DIY, good luck and hope all turns out well.
check out the instructions on p-car.com. They are very strightforward and spell out just about everything. The fronts are a piece of cake, the rears get a little tricky removing the big camber bolts and reaching the bolts on top of the shocks. It is very helpful to have a friend help with the rears. I think the DIY is worth it because you can take the time to clean the parts before they go back on, and it's good to know for sure that is was done right.
Richard,
I am in the process of performing the same install. I have received a lot of help the board. I will gladly pass on any information I gather during the install.
Dave
Dave
WENT TO WESTEND IN GARDENA, had FVD KIT INSTALLED BILSTEINS, EIBACHS,M030 SWAY BARS,CORNER BALANCE,ALIGNMENT,LABOR WAS $450.OO. DARIN REALLY KNOWS HIS STUFF AND IS A TRUE CRAFTSMEN......................YOU CANT GO WRONG WITH HIM.
SCOTT
SCOTT
motion. Go for it. I think you should give it a try. I think you will need to compress the springs. That is probably the trickest part. Oh getting your hands in behind the engine is not a piece of cake either.
$450.00 for the whole enchilada would be tempting. I think that is a great price.
I changed the shocks on my 911 and found that to a challenge.
I'm mustering up the courage to tackle the install of my PSS9s, which are in the garage and new sways which I have yet to decide whichs one the buys.
Good luck.
Good luck.
My HDs are on the way too, I'm planning on DIY. I run a TT, and I assume I have to remove the wheel well inner liner to get to the top bolts on the rears or is there a way from the removal in the rear deck lid from the interior?
I did NOT need a spring compressor on my DIY HD/M030 install..................Do it yourself, I am far from an auto mechanic and just followed the directions and Rennlist wise men ....AK
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Spring compressor is not needed either as the springs dont have much preload on them at all
A 'windowed' 21 (or 22mm) socket makes life easier in torquing up the shaft nuts. A 7mm 'L' allen wrench will hold the shaft. Also be careful not to overtighten the shaft nuts as there is no 'stretch' like a typical fastener. Torque wrench is best for this.
Originally Posted by chris walrod
Remove the airbox assy. and the HVAC blower assy. and this will give much more room to get at the damper mount nuts.
Just adding my .02 to let you know it's a lot easier than it's made out to be. Some people will get stuck at different places on the same install. That's why it's great to have this board to turn to for collective solutions.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
