Need Help - Speedo needle
I am in the process of installing the NR-Auto white face gauge kit. I have all of the gauges done and all went well except for the speedomenter. The needle here was diificult to remove but by turning counterclockwise and using the supplied tool, I finally got it off. I however, can't get it back on. I've spent the past hour trying everything. Anyone have any suggestions for getting this needle back on? Help appreciated.
Josh
Josh
Did the needle come off the shaft cleanly? It's possible it came off with part of the shaft. Do you have any pictures? Otherwise it should just slip on it in a straightforward manner.
