Stuck rear seatbelt retractor
When the seat belt is fully retracted onto the inertia reel, the ONLY way you can get it to release is to hold the inertia reel PERFECTLY vertical and pull straight up on the belt. Now in your case, if the reel is still mounted to the chassis under the interior panel, you will want to try to adjust the angle of the belt so that you are pulling it straight up versus the angle of the inertia reel (if that makes any sense). Alternatively, the panel is easy to remove and then you can unbolt the reel and give yourself some room to maneuver. Whatever you do, don't try to take apart the inertia reel - that is very dangerous and you will definitely ruin it. Good luck
Originally posted by David '97 993:
<STRONG>The rear seatbelt is stuck in the full retracted position. Can anyone tell me how it get it to release?</STRONG>
I tried to pull out the belts very hard like someone suggested (see archives on the old 993-996 board) . I also tried to be very gentle but all with no luck.
I don't want to try to repair the locking mechanism so I guess the only real solution is to replace both rear seat belts.
Addict & Guru
When my rear belt retractors have locked (2x), I freed them using a method Gert referenced (also discussed in the archives).
I exerted a very steady, but hard straight pull on the belt which took up some slack & then I abruptly let up causing the belt to "jump" in a bit. A few such efforts and the belt released. It's easier to do than to explain, but it worked. Good luck.
