Option Code 718???
Lead Rennlist
Technical Advisor
Lifetime Member
Quite common practice since 1993. The first use of option M718 I am aware was with the first of the RSAs. They had 1993 VINs but 1992 engines and were built in the 1992 model year.
Now some people will tell you that it is a 1994 model, brought up to 1995 specs and sold as a 1995 model. This is not entirely accurate. It is important to know this when ordering parts. This may help avoid getting something that does not fit or does not work.
What are the first three letters of the engine code. Your VIN 10th digit will be a "S" but I suspect the third digit of the engine code wll be a "R". If this is a "S" it means you have a 1995 motor. R means you have a 1994 motor.
Ciao,
Adrian
911C4
Thnks for the reply on the option code 718. The vin# for the car is as follows:
WP0AA2996SS320803
Lead Rennlist
Technical Advisor
Lifetime Member
Yes that would be the VIN I would expect. I would like to see the engine serial number as well. Just for interest you understand. These were all ROW 1994 models converted to 1995 US versions.
Ciao,
Adrian
911C4
