993 Forum 1995-1998
Aluminium instrument dials
Old Dec 19, 2001 | 09:26 AM
Jonas's Avatar
Jonas
Post Aluminium instrument dials
1. Where can I buy original OEM aluminium insturment dials for my 1996 993 C2?
2. Has anybody installed these dials on their car? Do I need to remove the facia or can I access the instruments from the front?
Very grateful for any hints.
Old Dec 20, 2001 | 10:13 PM
911Jeff's Avatar
911Jeff
Post
I did the swap in my 96 993... they pull out from the front, Mine were tight, so I used a flat head screw driver to gently pry them out. There is some sticky goo on them, so be careful. The wires ar via multi\pin plugs. The whole process is easy. The tach may require you to remove the steering wheel. Let me know if you need more detail.
Jeff
