993 Forum 1995-1998
RS Steering Wheel
Old Jan 3, 2005 | 05:27 PM
Russ8's Avatar
Russ8
Unhappy RS Steering Wheel
I have a 1997 993C4S and have recently changed the standard airbag steering wheel to a Porsche RS Steering wheel but am having trouble finding the correct RS part to make the horn work - can anyone help????
Old Jan 3, 2005 | 05:35 PM
akolodesh's Avatar
akolodesh
have you checked www.carnewal.com. I am sure if you email Gert, he will have the part you are looking for. May not be practical as the shipping from Europe for such a small part is probably pretty steep but it would be my first step.
Old Jan 3, 2005 | 05:43 PM
akolodesh's Avatar
akolodesh
BTW, how do you like the feel of the RS wheel? I have been considering changing to that wheel for some time now.
Old Jan 3, 2005 | 05:50 PM
Russ8's Avatar
Russ8
Thanks for that site I'll give it a try I'm in Europe so it will probably be worth it. The RS wheel is a slightly narrower diameter, a thinner rim and personally I feel it gives more feel and feedback back thru the steering.
Old Jan 3, 2005 | 06:03 PM
akolodesh's Avatar
akolodesh
Thanks for the input about the wheel. Since you're in Europe Gert's site is definitely the way to go. He is very helpful and conscientious. I would be careful though, once you go on the site you will be hooked!!
Old Jan 3, 2005 | 06:57 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Are you looking for the slip-ring? #993-347-099-81
Old Jan 3, 2005 | 07:25 PM
Russ8's Avatar
Russ8
I have the brass slip ring that came with the steering wheel, what I am looking for is the contact points to take the power to the slip ring on the steering wheel - I am thinking that maybe they look like some form of sprung loaded carbon bushes. I am failing miserably with my local Porshe Dealers they don't seem to know what I require.
Old Jan 4, 2005 | 04:06 AM
JasonAndreas
Technical Guru
The only other 993RS specific part I can find is the plate for the steering column switch, #964-652-104-00. If you stop by your local dealer have them ATP that part # or look at PET MG-6 SG-03 Illus-903-10 (not the regular steering wheel section in PET).
Old Jan 4, 2005 | 11:12 AM
Russ8's Avatar
Russ8
Thanks very much I have now ordered that part which sounds like the right one.
Old Jan 4, 2005 | 11:38 AM
joolsbourne's Avatar
joolsbourne
Very good, "sounds like the right part" ... horn.... get it????
Jools
